zbpattern(
NUMBER
PATTERN
The zbpattern( function converts a number to text using a pattern, but returns empty text if the number is zero.
This function has two  parameters:
number – the number to convert.
pattern – the pattern to be used to convert the number to text. See Numeric Patterns for more information.
This function converts a number to text using a pattern. Unlike the normal pattern( function, the zbpattern( function will output "" if the number is zero. (Note: zb is short for zeroblank.)
zbpattern(1234,"#,.##") ☞ 1,234.00
zbpattern(0,"#,.##") ☞
?(thenum=0,"",pattern(thenum,thepat))
