nthline(
TEXT
NUMBER
The nthline( function extracts the nth line from the text.
text – the original text.
number – position of the line to extract (1 for first line, 2 for second line, etc.) You can also use a negative number to specify the position from the end of the text (-1 for last line, -2 for second to last line, etc.)
This function extracts the nth line from the text.
nthline("red
green
blue
yellow
orange",2) ☞ green
Negative values allow you to specify the line position relative to the end of the text (-1 for the last line, -2 for the second to last, etc.)
nthline("red
green
blue
yellow
orange",-2) ☞ yellow
array(thetext,num,cr())
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
| 10.0 | Updated | Carried over from Panorama 6.0, but now allows negative position values to specify the line position from the end of the text. |
