batchreplace(
TEXT
FINDREPLACEPAIRS
MAINSEPARATOR
SUBSEPARATOR
The batchreplace( function performs multiple find/replace operations on a piece of text.
text – text to be modified.
findreplacepairs – two dimensional text array specifying the find and replace operations to be done. Each array element is itself a two element array … element 1 is the text to be found, element 2 is the replacement text.
mainseparator – the separator between each replacement pair.
subseparator – the separator between each find/replace element.
This function performs multiple find/replace operations on a piece of text. This example converts a state abbreviation into a full state name.
batchreplace("CA","AZ=Arizona|CA=California|OR=Oregon","|","=") ☞ California
This function is similar to replacemultiple( but is easier to set up and modify because the find & replace strings are grouped together, instead of being split into separate arrays.
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
