concatenate(
FIRST
SECOND
The concatenate( function concatenates two text strings (same as the + operator).
first – first text value.
second – second text value
This function concatenates two text strings (same as the + operator).
concatenate("hello"," kitty") ☞ hello kitty
a+b
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
