fixedwidthright(
TEXT
WIDTH
The fixedwidthright( function makes the text a fixed width, padding on the left with spaces if necessary.
text – the original text.
width – desired number of characters.
This function makes the text a fixed width. If the text is shorter than the specified width, it is padded with spaces on the left (i.e. the text is right justified). If it is longer than the specified width, it is cut off on the left.
fixedwidthright("abcd xyz",12)+" tab" ☞ abcd xyz tab
fixedwidthright("abcd",12)+" tab" ☞ abcd tab
Note that this makes the text a fixed number of characters – it does not take variable character width based on fonts into account.
(rep(" ",thewidth)+thetext)[-thewidth,-1]
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
