datepattern(
DATE
PATTERN
The datepattern( function converts a number representing a date into text. The function uses a pattern to control how the date is formatted (see Date Patterns).
date – is the number you want to convert to text. This number is treated as the number of days since January 1, 4713 B.C.
pattern – is text that contains a pattern for formatting the date (see Date Patterns).
This function converts a number representing a date into text. The function uses a pattern to control how the date is formatted (see Date Patterns).
datepattern(today(),"mm/dd/yy") ☞ 8/9/12
datepattern(today(),"MM/DD/YY") ☞ 08/09/12
datepattern(today(),"mm/dd/yyyy") ☞ 8/9/2012
datepattern(today(),"Month ddnth, yyyy") ☞ August 9th, 2012
datepattern(today(),"dd-MON-yy") ☞ 9-AUG-12
datepattern(today(),{DayOfWeek, Month ddnth, yyyy}) ☞ Thursday, August 9th, 2012
datepattern(today(),{Qtr "Quarter" yyyy}) ☞ 3rd Quarter 2012
datepattern(today(),"YYYYMMDD") ☞ 20120809
You can even use datepattern( to change an existing date pattern into something else.
thedate="7/4/1776"
message datepattern(date(thedate),"DayOfWeek, Month ddnth, yyyy")
☞ "Thursday, July 4th, 1776"
- calendardate( -- helps in creating monthly calendars.
- calendarday( -- helps in creating monthly calendars.
- datevalue( -- converts integer values for year, month and day into a number representing a date.
- dayofmonth( -- computes the day within a month.
- dayofquarter( -- computes the day within a quarter.
- dayofweek( -- computes the day of the week, with Sunday being 0, Monday 1, etc.
- dayofyear( -- computes the day within a quarter.
- dayvalue( -- extracts the day from a date as a numeric value.
- firstdayofweek( -- returns the user's preference for first day of the week.
- month1st( -- computes the first day of a month.
- monthlength( -- computes the length (number of days) of a month.
- monthmath( -- takes a date and computes the date that is one or more months before or after the original date.
- monthvalue( -- extracts the month from a date as a numeric value.
- quarter1st( -- computes the first day of a quarter.
- quartervalue( -- extracts the quarter from a date as a numeric value.
- regulardate( -- extracts a regular date (number of days from January 1, 4713 B.C.) from a superdate.
- today( -- returns a number corresponding to today's date.
- week1st( -- computes the first day of a week (Sunday).
- weekvalue( -- extracts the week from a date as a numeric value.
- year1st( -- computes the first day of a year.
- yearvalue( -- extracts the year from a date as a numeric value.
