The randomletter( function returns a random letter.
This function has one parameter:case – determines the case of the randomly generated character. If this option is "l"
or "L"
then the letter will be lower case (between a and z). if the option is "u"
or "U"
then the letter will be upper case (between A and Z). if the option is any other value, then the result may be either upper or lower case.
This function returns a random letter. Each time you use it a new random letter will be returned.
randomletter("x") ☞ D
randomletter("x") ☞ o
randomletter("x") ☞ W
randomletter("x") ☞ b
randomletter("x") ☞ u
If you want all upper case letters, set the option to "U"
randomletter("U") ☞ D
randomletter("U") ☞ S
randomletter("U") ☞ K
randomletter("U") ☞ B
randomletter("U") ☞ N
If you want all lower case letters, set the option to "L"
randomletter("L") ☞ y
randomletter("L") ☞ a
randomletter("L") ☞ f
randomletter("L") ☞ m
randomletter("L") ☞ q
?(upper(option)="U",chr(int(65+26*rnd())),?(upper(option)="L",chr(int(97+26*rnd())),
?(int(1+2*rnd())=1,chr(int(65+26*rnd())),chr(int(97+26*rnd())))))
