textafter(
TEXT
TAG
The textafter( function extracts the text after the tag.
text – the original text
tag – the separator character (or characters).
This function extracts the text that appears after a specified tag. The tag many be one or more characters long. If the tag doesn’t occur in the text then the entire original string is returned.
textafter("someone@anisp.net","@") ☞ anisp.net
To extract text before a tag, use the textbefore( function.
?(thetext contains thetag,thetext[length(thetag)+search(thetext,thetag),-1],thetext)
