right(
TEXT
LENGTH
The right( function extracts characters from the right edge of the text.
text – original text
length – number of characters to extract from the end of the original text. Any characters before this point will be discarded.
This function extracts one or more characters from the right edge of the text. For example right(text,7) extracts the rightmost seven characters from the end of text.
right("abcdef",1) ☞ f
right("abcdef",3) ☞ def
right("abcdef",12) ☞ abcdef
text[-len,-1]
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
