fixedwidth(
TEXT
WIDTH
The fixedwidth( function makes the text a fixed width, padding with spaces if necessary.
text – the original text.
width – desired number of characters.
This function makes the text a fixed width. If the text is shorter than the specified width, it is padded with spaces. If the text is longer than the specified width, it is cut off.
fixedwidth("abcd xyz",12)+"tab" ☞ abcd xyz tab
fixedwidth("abcd",12)+"tab" ☞ abcd tab
Note that this makes the text a fixed number of characters – it does not take variable character width based on fonts into account.
(thetext+rep(" ",thewidth))[1,thewidth]
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
