onespace(
TEXT
The onespace( function removes all leading & trailing spaces and any extra spaces between words, so that there is exactly one and only one space between each word.
text – the original text.
This function removes all leading & trailing spaces and any extra spaces between words, so that there is exactly one and only one space between each word.
onespace(" now is the time") ☞ now is the time
See also the onewhitespace( function, which also removes extra line breaks and tabs between words.
arraystrip(thetext," ")
- appendluhncheckdigit( -- adds a Luhn check digit to a series of digits.
- obfuscate( -- randomizes the letters and digits in text.
- obscuredigits( -- obscures digits in a number (usually a credit card number) with Xs.
- replacefirst( -- replaces the first occurence of some text with new text.
