before(
TEXT
TAG
The before( function extracts all text before a specified tag (sequence of characters). If the tag doesn’t exist the function returns “”.
text – the original text
tag – the separator character (or characters).
This function extracts all text before a specified tag (sequence of characters). If the tag doesn’t exist the function returns “”.
before("john.doe@isp.com","@") ☞ john.doe
tagdata(chr(255)+chr(254)+chr(253)+thetext,chr(255)+chr(254)+chr(253),thetag,1)
