The jsonexport( function converts a Panorama dictionary or data array into JSON.
This function has one parameter:data – The dictionary or data array to export as JSON.
This function exports a Panorama dictionary or data array into JSON. (JSON is a data interchange format that is used by many web APIs. See http://www.json.org for more information.)
The data passed to this function must be either a Panorama dictionary or a Panorama data array. Let’s take a look at an example of a dictionary.
local person
person = initializedictionary(
"ID",2192,
"Name","Wilson, Thomas",
"Title","Executive",
"Location","Santa Barbara",
"Salary",83500)
We can display this information in JSON format using the jsonexport( function.
displaydata jsonexport(person)
The result will look like this:
"ID" : 2192,
"Salary" : 83500,
"Name" : "Wilson, Thomas",
"Location" : "Santa Barbara",
"Title" : "Executive"
Note: As you can see in the example above, the order of the elements in the JSON record is not necessarily the same as the order the elements were defined in the Panorama dictionary. Panorama dictionaries have no defined order.
Data arrays can also be converted to JSON. Start with a data array, like this:
local colors
colors = dataarray("Red","Purple","Teal")
Note: If you have a text array, you must convert it to a data array using the importdataarray( function before converting it to JSON.
We can display this array in JSON format using the jsonexport( function.
displaydata jsonexport(colors)
"Red",
"Purple",
"Teal"
In addition to basic dictionaries and arrays, data structures can be nested. Here is an example of an array nested within a dictionary.
local person
"ID",3298,
"Name","Zanhof, Steven",
"Title","Sales Engineer",
"Location","Tustin",
"Territories",dataarray("Orange","Riverside","San Bernadino","San Diego"),
"Salary",76400)
Here’s what this looks like in JSON format.
"ID" : 3298,
"Territories" : [
"Orange",
"Riverside",
"San Bernadino",
"San Diego"
"Salary" : 76400,
"Name" : "Zanhof, Steven",
"Location" : "Tustin",
"Title" : "Sales Engineer"
This example shows an array nested within a dictionary, but you can also start with an array and nest one or more dictionaries within the array. Dictionaries and data arrays can be nested as deep as you want.
Note: In addition to data interchange, the jsonexport( function is also very handy for displaying complicated data structures, which can be very handy in debugging code that handles these sorts of structures.
The JSON format allows a data value to be unspecified, this is called a null value. To include null values in the generated JSON text, use the error("null")
function, as shown in this code:
local person
"ID",2192,
"Location",error("null"),
"Salary",error("null"))
let jsonPerson = jsonexport(person)
The resulting JSON text will include redacted values for the location and salary:
"ID" : 2192,
"Salary" : null,
"Location" : null,
The ?( function can be used to conditionally redact information. This example will redact the salary if it is over 80k:
local person
"ID",EmployeeID,
"Name",EmployeeName,
"Title",EmployeeTitle,
"Location",EmployeeOffice,
"Salary",?(EmployeeSalary<80000,80000,error("null"))
Note: Use of the error("null")
function with the jsonexport( function requires Panorama X 10.2 or later.
10.2 | Updated | This function can now include null values in the JSON data. |
