lftocr(
TEXT
The lftocr( function converts linefeeds into carriage returns.
text – the original text containing linefeeds or carriage return line feeds.
This function converts linefeeds into carriage returns. It will also convert any carriage return/linefeed pairs into carriage returns. For example, you could use this to convert any text file into carriage return delimited text, even if it was saved with linefeeds or crlf delimiters.
lftocr(fileload(some file))
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
