notbetween(
VALUE
MINIMUM
MAXIMUM
The notbetween( function checks to see if a value is not between two other values.
value – the value to check. The value may be a number, date or text.
minimum – the minimum value that matches. The minimum must be the same type as the value parameter.
maximum – the maximum value that matches. The maximum must be the same type as the value parameter.
This function checks to see if a value is between two other values. The result will be false if the value is equal to either the minimum or maximum value or lies between them. If the value is outside this range the result will be true.
notbetween(15,10,20) ☞ 0 (false)
notbetween(45,10,20) ☞ -1 (true)
notbetween("m","a","g") ☞ -1 (true)
notbetween("c","a","g") ☞ 0 (false)
notbetween(today(),date("monday"),date("friday")) ☞ 0 (false)
The final example above checks to see if today is a weekend. If today is Monday thru Friday the formula returns false, for Saturday and Sunday, it returns true.
thevalue<themin or thevalue>max
