hexbyte(
VALUE
The hexbyte( function converts a limited range of decimal numbers to a two-digit hexadecimal number expressed as a text string.
value – is the decimal number you want to convert to hexadecimal. The value should be from 0 to 255.
Converts a limited range of decimal numbers to a two-digit hexadecimal number expressed as a text string. See Non Decimal Numbers for background information on hexadecimal numbers.
hexbyte(68) ☞ 44
hexbyte(230) ☞ E6
radixstr("hex",number)[-2,-1]
