linecount(
TEXT
The linecount( function counts the number of carriage return separated lines in the text.
text – the original text with multiple lines.
This function counts the number of carriage return separated lines in the text.
linecount("red
green
blue
yellow
orange") ☞ 5
extract(thetext,cr(),-1)
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
