limit(
VALUE
MINIMUM
MAXIMUM
The limit( function checks to see if a value is between a minimum and maximum value. If it is, the value is returned unchanged. If it is below the minimum, the minimum value is returned. If it is above the maximum the maximum value is returned.
value – the original value. This value may be a number, a date, or text.
minimum – the minimum value to be returned. The minimum may be a number, a date, or text, but the type must be the same as the value parameter.
maximum – the maximum value to be returned. The maximum may be a number, a date, or text, but the type must be the same as the value parameter.
This function checks to see if a value is between a minimum and maximum value. If it is, the value is returned unchanged. If it is below the minimum, the minimum value is returned. If it is above the maximum the maximum value is returned.
limit(5 , 10 , 20) ☞ 10
limit(15 , 10 , 20) ☞ 15
limit(25 , 10 , 20) ☞ 20
limit("A" , "D" , "J") ☞ D
limit("G" , "D" , "J") ☞ G
limit("X" , "D" , "J") ☞ J
min(max(thevalue,themin),themax)
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
