randomline(
TEXT
The randomline( function returns a random line from multiple lines of text.
text – one or more lines of text, separated by carriage return characters.
This function returns a random line from multiple lines of text. Each time you use this function a new random line will be returned.
randomline(commatocr("red,green,blue,gold,silver,white,black")) ☞ blue
randomline(commatocr("red,green,blue,gold,silver,white,black")) ☞ silver
randomline(commatocr("red,green,blue,gold,silver,white,black")) ☞ red
randomline(commatocr("red,green,blue,gold,silver,white,black")) ☞ gold
new
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- tab( -- generates a tab.
10.0 | Updated | Carried over from Panorama 6.0, but is much faster. |
