urldecode(
TEXT
The urldecode( function decodes text that contains percent encoded characters.
text – text to be decoded.
This function decodes text that contains percent encoded characters.
urldecode("now%20is%20the%20time") ☞ now is the time
The RFC 2396 standard discusses different options for escaping characters when creating a URL.
- cgilink( -- creates a domain independent URL for another CGI action on the same server.
- cgilinknewwindow( -- creates a domain independent link for another CGI action on the same server that opens a new browser window.
- cginavlink( -- creates a domain-independent navigation link for the current record in this database.
- cginavlinknewwindow( -- creates a domain-independent navigation link (to a new browser window) for the current record in this database.
- htmldecode( -- converts HTML text into regular text by converting any special HTML entities (`&`, `©`, etc.) into the corresponding characters.
- htmlencode( -- converts standard text into HTML text by converting any special characters into the equivalent HTML entities.
- webformlink( -- generates a link to a Panorama form on the current web site (the link will open in a new browser window).
- webformlinknewwindow( -- generates a link to a Panorama form on the current web site.
- weblink( -- builds an HTML link tag
- weblinknewwindow( -- builds an HTML link tag
