stripdiacriticals(
TEXT
The stripdiacriticals( function strips diacritical marks from text.
text – the item of text that you want to strip.
This function removes diacritical marks (umlauts, etc.) from letters. Here are three examples of how this function works.
stripdiacriticals("Álgebra") ☞ Algebra
stripdiacriticals("dän") ☞ dan
stripdiacriticals("dün") ☞ dun
