striptoalpha(
TEXT
The striptoalpha( function removes everything but alphabetic letters from a text item.
text – is the item of text that you want to strip.
The striptoalpha( function removes everything but alphabetic letters from a text item. Everything else (numbers, spaces, punctuation, non-English letters, etc.) will be removed from the text.
striptoalpha("Joy's birthday is on 7/12") ☞ Joysbirthdayison
