nthword(
TEXT
NUMBER
The nthword( function extracts a word from the middle of the text.
text – original text.
number – position of the word to extract (1 for first word, 2 for second word, etc.) You can also use a negative number to specify the position from the end of the text (-1 for last word, -2 for second to last, etc.)
This function extracts the nth word from the text. For example nthword(text,4) extracts the fourth word.
nthword("now is the time",1) ☞ now
nthword("now is the time",2) ☞ is
nthword("now is the time",4) ☞ time
nthword("now is the time",-1) ☞ time
nthword("now is the time",-2) ☞ the
array(thetext,thenum," ")
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
| 10.0 | Updated | Carried over from Panorama 6.0, but now allows negative position values to specify the word position from the end of the text. |
