linesort(
LINES
The linesort( function sorts lines of text in ascending order.
lines – the lines of text to sort. Each line must be terminated with a carriage return character.
This function sorts lines of text in ascending order.
The function is equivalent to:
arraysort(text,¶)
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
