crtolf(
TEXT
The crtolf( function converts carriage returns into linefeeds.
text – the original text containing carriage returns or carriage return line feeds.
This function converts carriage returns into linefeeds. It will also convert any carriage return/linefeed pairs into linefeeds. For example, you could use this to convert any text file into linefeed delimited text, even if it was saved with carriage return or crlf delimiters.
crtolf(fileload(some file))
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- tab( -- generates a tab.
