removesuffix(
TEXT
SUFFIX
The removesuffix( function checks to see if a text item ends with a suffix. if it does, the suffix is removed.
text – text that may or may not have a suffix.
suffix – suffix value to remove.
This function checks to see if a text item ends with a suffix. If it does, the suffix is removed.
removesuffix("abc.",".") ☞ abc
removesuffix("37¢","¢") ☞ 37
?(thetext endswith thesuffix,trim(thetext,length(thesuffix)),thetext)
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- tab( -- generates a tab.
