crtovtab(
TEXT
The crtovtab( function converts carrige returns (ASCII 0x0D) into vertical tabs (ASCII 0x0B).
text – the original text containing zero or more carriage returns.
This function converts carrige returns (ASCII 0x0D) into vertical tabs (ASCII 0x0B). Some programs (including Panorama) will convert vertical tabs into carriage returns when importing, allowing individual data cells to contain carriage returns.
crtovtab("alpha
beta
gamma") ☞ alpha↘beta↘gamma
replace(thetext,cr(),chr(11))
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- tab( -- generates a tab.
