perlscriptstring(
TEXT
The perlscriptstring( function converts text into a Perl string literal.
text – the original text.
This function converts text into an Perl string literal. To do this, the function surrounds the text with single quote characters, and escapes any single quote and/or backslash characters within the text. (Note: You could also use the applescriptstring( function to create a perl string literal that would be subject to variable substitution.) Use this function when you need a string literal inside the Perl statement or perl( function.
perlscriptstring({Make text into 'perl' "literal string"})
☞ 'Make text into \'perl\' "literal string"'
{'}+replace(replace(thetext,{\},{\\}),{'},{\'})+{'}
- applescriptconstant( -- converts an expression into an AppleScript literal.
- javascriptconstant( -- converts an expression into a JavaScript literal.
- javascriptstring( -- converts a text string into a JavaScript string
- perlconstant( -- encodes text for use as a constant in a Perl program.
- phpconstant( -- encodes text for use as a contant in a php program.
- pythonconstant( -- encodes text for use as a constant in a python program.
- rubyconstant( -- encodes a value for use as a constant in a Ruby program.
- runningappinfo( -- returns information about applications that are currently running on this computer.
- Scripting Panorama X with AppleScript -- embedding Panorama code into AppleScript (allowing Panorama to be controlled from other programs).
- unixshellstring( -- encodes text for use as a parameter to a unix shell command.
