lookupallseptuplet(
DATABASE
KEYFIELD
KEYDATA
DATAFIELDONE
DATAFIELDTWO
DATAFIELDTHREE
DATAFIELDFOUR
DATAFIELDFIVE
DATAFIELDSIX
DATAFIELDSEVEN
SEPARATOR
SUBSEPARATOR
The lookupallseptuplet( function is similar to the lookupall( function, but it returns seven fields from the target database instead of just one.
This function has twelve parameters:
database – is the database that will be scanned. This database must be currently open. If this parameter is "" then the current database will be scanned. Note: The lookupall( function will scan every record in the database, including records that are not currently selected. If you want to build an array from only selected records, use the arrayselectedbuild( function.
datafieldone – is the name of the first field that you want to retrieve data from. For example if you want to retrieve check numbers, this should be the name of the field that contains check numbers. This must be a field in the database specified by the first parameter. Note: This function can optionally handle multiple data fields, with a separator, see below for further information.
datafieldtwo – the second field to retrieve data from.
datafieldthree – the third field to retrieve data from.
datafieldfour – the fourth field to retrieve data from.
datafieldfive – the fifth field to retrieve data from.
datafieldsix – the sixth field to retrieve data from.
datafieldseven – the seventh field to retrieve data from.
separator – is the main separator character for the text array you are building (see Text Arrays). This separator will be placed between each retrieved record.
subseparator – the secondary separator character. This separator will be placed between the data fields.
This function is similar to the lookupall( function, but it returns seven fields from the target database instead of just one.
lookupallseptuplet("My Address Book","Title","CIO","First","Last","Organization","City","State","Zip","Phone1",cr()," ")
arraymerge(arraymerge(arraymerge(arraymerge(arraymerge(arraymerge(lookupall(thedb,keyfield,keyvalue,datafieldone,mainsep),lookupall(thedb,keyfield,keyvalue,datafieldtwo,mainsep),mainsep,subsep),lookupall(thedb,keyfield,keyvalue,datafieldthree,mainsep),mainsep,subsep),lookupall(thedb,keyfield,keyvalue,datafieldfour,mainsep),mainsep,subsep),lookupall(thedb,keyfield,keyvalue,datafieldfive,mainsep),mainsep,subsep),lookupall(thedb,keyfield,keyvalue,datafieldsix,mainsep),mainsep,subsep),lookupall(thedb,keyfield,keyvalue,datafieldseven,mainsep),mainsep,subsep)
