trimleft(
TEXT
COUNT
The trimleft( function removes one or more characters from the left edge of the text.
text – is the original text.
count – is the number of characters to remove from the beginning of the text.
This function removes one or more characters from the beginning (left edge) of the text.
trimleft("abcdef",1) ☞ bcdef
trimleft("abcdef",2) ☞ cdef
trimleft("abcdef",12) ☞
If you want to trim characters from the right end of the text, use the trim( function.
text[count,-1]
10.0UpdatedCarried over from Panorama 6.0, however, this function has been fixed to remove the exact count supplied. In previous versions of Panorama, one less than the count would be removed.
