connect(
PREFIX
CONNECTOR
SUFFIX
The connect( function appends a prefix and suffix together with a connector in between.
prefix – word or phrase to be used as a prefix
connector – text to be used in between the prefix and suffix if both are present.
suffix – word or phrase to be used as a suffix
This function appends a prefix and suffix together with a connector in between. If either the prefix or the suffix is missing, the connector will also be left out. For example, connect(City,", ",State) combines the city and state with a comma and space in between, but if either the city or state is missing then the comma and space will also be left out.
connect("Fullerton",", ","CA") ☞ Fullerton, CA
connect("Fullerton",", ","") ☞ Fullerton
connect("",", ","CA") ☞ CA
The sandwich( function performs a similar operation.
?(prefix<>"" and suffix<>"",prefix+connector+suffix,prefix+suffix)
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
