textbefore(
TEXT
TAG
The textbefore( function extracts the text before the tag.
text – the original text
tag – the separator character (or characters).
This function extracts the text that appears before a specified tag. The tag many be one or more characters long. If the tag doesn’t occur in the text then the entire original string is returned.
textbefore("someone@anisp.net","@") ☞ someone
To extract text after a tag, use the textafter( function.
thetext[1,-1+search(thetext,thetag)]
