linesnotcontain(
LINES
VALUE
The linesnotcontain( function is the reverse of the linescontain( function.
lines – text with multiple lines, separated by carriage returns.
value – value to look for. For the function to return false, the value must exactly match one of the lines in the text, including upper and lower case.
This function is the reverse of the linescontain( function.
linesnotcontain("a
b
c","x") ☞ -1 (true)
linesnotcontain("a
b
c","b") ☞ 0 (false)
(not arraycontains(thelines,thevalue,cr()))
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
