chunkarray(
DATA
INDEX
CHUNKLENGTH
The chunkarray( function extracts a binary “chunk” from binary data (see Binary Data).
data – binary data containing one or more byte (8-bit) values. See Binary Data for more information on this type of data.
index – position of the desired byte, starting from 1.
chunklength – the length of each “chunk”, in bytes.
This function extracts a binary chunk from an array of chunks. This is not a Panorama style delimited array but a C style array of binary chunks. The result is a binary value (See Binary Data), which in this example Panorama has automatically converted to text (see the binarytotext( function).
chunkarray(byte(65)+byte(82)+byte(96)+byte(78)+byte(99)+byte(87),2,3) ☞ NcW
Note: This function will actually work with either binary data or text. If the data parameter is text, the result will also be text.
chunkarray("abcdefghiljklmnopqrstuvwxyz",2,4) ☞ efgh
(thetext)[1+(index-1)*chunklength;chunklength]
