removeprefix(
TEXT
PREFIX
The removeprefix( function checks to see if a text item starts with a prefix. if it does, the prefix is removed.
text – text that may or may not have a prefix.
prefix – prefix value to remove.
This function checks to see if a text item starts with a prefix. If it does, the prefix is removed.
removeprefix("18005551212","1") ☞ 8005551212
removeprefix("Mr. John Doe","Mr. ") ☞ John Doe
?(text beginswith prefix,text[length(prefix)+1,-1],text)
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
