places(
NUMBER
PLACES
The places( function converts a number to text with a specific number of places after the decimal point.
number – a numeric value.
places – number of places after the decimal point.
This function converts a number to text with a specific number of places after the decimal point. The value is truncated (not rounded) to the number of places specified.
places(1.23456,10) ☞ 1.2345600000
places(1.23456,3) ☞ 1.234
array(str(thenumber),1,".")+"."+(array(str(thenumber),2,".")+rep("0",theplaces))[1,theplaces]
