firstline(
TEXT
The firstline( function extracts the first line from the text.
text – the original text, with one or more lines
This function extracts the first line from the text.
firstline("red
green
blue
yellow
orange") ☞ red
array(thetext,1,cr())
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
