sandwich(
PREFIX
ROOT
SUFFIX
The sandwich( function assembles a text item from three smaller items.
prefix – is the item of text that the final text will start with.
root – is the main character, word or phrase that you want to include in the final text. If the root is empty, the entire assembled text will be empty.
suffix – is the item of text that the final text will end with.
The sandwich( function assembles a text item from three smaller text items. To do this, it slaps the prefix and suffix onto the ends of the root, just like a sandwich. However, if the root is empty, the prefix and suffix are also left off (the result is an empty text item), just as you wouldn’t make a sandwich without any meat.
sandwich("[[[","Welcome to the Future!","]]]") ☞ [[[Welcome to the Future!]]]
sandwich("[[[","","]]]") ☞
- ?( -- allows a formula to make a true/false, yes/no decision.
- croptext( -- crops text to a specified length. If the text was already shorter than the specified length, it is left unchanged. If it is longer, the text is cut off and an ellipsis is added on the end.
- regexreplacefirst( -- replaces the first occurrence of a regular expression pattern with new text.
- regexreplacefirstexact( -- replaces the first occurrence of a regular expression pattern with new text.
- replacefirst( -- replaces the first occurence of some text with new text.
