onewhitespace(
TEXT
The onewhitespace( function removes all leading spaces and any extra whitespace between words, making sure that there is one and only one space between each word.
text – the original text.
This function removes all leading spaces and any extra whitespace between words, making sure that there is one and only one space between each word. Other whitespace characters (carriage returns, tabs) are converted to spaces and removed if there are more than one between words.
onewhitespace(" now is the "+tab()+"time"+cr()+cr()+"line three"+cr()+cr()+"five")
☞ now is the time line three five
arraystrip(replace(replace(thetext,cr()," "),tab()," ")," ")
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
