getprocedureoption(
DATABASE
PROCEDURE
OPTION
The getprocedureoption( function returns information about a procedure.
database – The database that contains the procedure you want information about, or "" for the current database.
procedure – The name of the procedure you want to get information about, or "" for the currently open procedure (if a procedure editor window is active).
option – The type of information you want to retrieve. See below for descriptions of each option. This parameter is optional, if left off, the ALL option will be used.
This function retrieves information about any procedure in any open database.
ALL
This option returns a dictionary that contains all of the option values associated with this procedure. You can extract individual options with the getdictionaryvalue( function. (You can also get this dictionary by simply omitting the option parameter.) This example displays information about a procedure’s syntax error (if it has one).
local pinfo
pinfo = getprocedureoption("","SomeProcedure")
if getdictionaryvalue(pinfo,"ERROR") <> ""
message "Error in procedure "+getdictionaryvalue(pinfo,"NAME")+cr()+cr()+
getdictionaryvalue(pinfo,"ERROR")+cr()+
"CODE:"+getdictionaryvalue(pinfo,"SOURCE")[getdictionaryvalue(pinfo,"ERRORSTART"),
getdictionaryvalue(pinfo,"ERROREND")]
SOURCE
This option returns the source code of the specified procedure. This example uses this option to create a list of procedures in the current database that contain the word message.
local proclist
proclist = dbinfo("procedures","")
proclist = arraystrip(arrayfilter(proclist,cr(),
{?(getprocedureoption("",import(),"SOURCE") contains "message",import(),"")}),cr())
message proclist
ERROR
This option checks to see if the procedure has a syntax (compile time) error, and if so, reports the error. If there is no error, "" is returned. This example returns a list of the procedures in the current database that contain an error.
local proclist
{?(getprocedureoption("",import(),"ERROR") <>"",import()+
":"+getprocedureoption("",import(),"ERROR"),"")}),cr())
message proclist
The output of this procedure will be something like this:
AddInvoice:Unknown statement:totals
VoidInvoice:Missing Right Parenthesis
ERRORSTART
If the specified procedure contains an error, this option will return the starting position of the error within the source code.
ERROREND
If the specified procedure contains an error, this option will return the ending position of the error within the source code.
LABELS
This option returns a carriage return delimited list of labels defined in the specified procedure (if any).
If this option is false, the procedure is displayed in the View menu. If this option is true, the procedure will be excluded from the View menu.
POSITION and SIZE
The “windowleftedge”, “windowtopedge”, “windowrightedge” and “windowbottomedge” options return the saved dimensions of the procedure window (whether it is currently open or not). The “windowrectangle” function returns a rectangle with all four coordinates.
TAG
This option returns the tag you have assigned to this procedure (if any). You can use the tag value for whatever you want, Panorama stores the tag for you but does not use or interpret it in any way.
Window Options
The following options return information about the window associated with the specified procedure (if there is an open window).
WINDOWNAME
If the window for this procedure is open, this option returns the name of the window (if not open, returns empty text).
WINDOWNUMBER
If the window for this procedure is open, this option returns the ID number of the window (if not open, returns zero). See Window ID Numbers to learn more about using this option.
### Menu Options ###
The following options modify the appearance and operation of the Action menu item associated with the specified procedure.
This option returns the color the Action menu item associated with the specified procedure.
colorHue = hue(getprocedureoption("","FedEx","MENUCOLOR"))
See Colors for more information about using colors with Panorama.
This option checks whether the Action menu item associated with this procedure is disabled (dim).
RushAvailable = getprocedureoption("","Rush","MENUDISABLED") = false()
Panorama normally has special treatment for procedure names that start with the ( symbol, but this special treatment can be turned off on a menu item by item basis. This option checks to see whether the special ( treatment is enabled or not.
getprocedureoption("","(213) 555=1212","MENUDISPLAYLEADINGPARENTHESES")
This option returns the font assigned to the Action menu item associated with the specified procedure.
if getprocedureoption("","People","MENUFONT") = "Marker Felt"
message "Really?"
Note: If the item uses the system menu font this function will return "".
This option returns the font size for the Action menu item associated with the specified procedure. The size is specified in points.
if getprocedureoption("","Big Big People","MENUFONTSIZE") > 24
message "Wow, that's big!"
This option returns the indent level of the Action menu item associated with this procedure.
This option returns true if the specified procedure is invisible (not included in the Action menu). Note: This option does not return true for procedures with names beginning with a period, or procedures following a () procedure, even though those are also invisible.
This option returns the command key equivalent, if any, for the Action menu item associated with this procedure.
if getprocedureoption("",someProcedure,"MENUKEY") <> ""
message "This item has a command key equivalent"
This option returns any modifier keys for the command key equivalent associated with this procedure. The available modifier keys are "SHIFT", "OPTION" and "CONTROL". You can use these options separately or in combination.
if getprocedureoption("","Color","MENUKEYMODIFIERS","shift") contains "OPTION"
This option returns whether or not the Action menu item associated with the procedure has a checkmark.
if getprocedureoption("","Shipped","MENUSTATE") = "ON" // checked
// shipped
if getprocedureoption("","Shipped","MENUSTATE") = "" // not checked
// not shipped
if getprocedureoption("","Shipped","MENUSTATE") = "MIXED" // dash
// partially shipped
This option returns the style used by the Action menu item associated with the specified procedure.
if getprocedureoption("","People","MENUSTATE") contains "italic"
if getprocedureoption("","People","MENUSTATE") = ""
// plain text
| 10.2 | Updated | Added the excludefromviewmenu, windowname and windownumber options. |
| 10.0 | New | This function is new in this version. |
