info("picturesfolder")
The info(“picturesfolder”) function returns the path to the current user’s Pictures folder.
This function returns the path to the current user’s Pictures folder.
Note: This function allows language independent access to the Pictures folder, and will correctly locate the folder even if you are using a non-English system.
