info("windowdepth")
The info(“windowdepth”) function returns the color depth of the current window.
This function returns the color depth of the current window. Back in the “olden days” this function would return 1 for black and white monitors, or 8 for gray monitors. Now this function always returns 32, but it is retained for legacy compatibility.
