info("fieldcount")
The info(“fieldcount”) function returns the number of fields in the current database.
This function returns the number of fields in the current database. For example, you could use it to test to see if the current field is the last field of the database.
info("fieldnumber")=info("fieldcount") ☞ true if currently on last field
Here is an example that shows how to create a procedure that scans every field in the database from left to right, performing some operation on each field.
for fn,1,info("fieldcount")
field fn+0
// DO SOMETHING FOR EACH FIELD
endloop
- field -- tells Panorama to move to the specified field for the current record.
- fieldblueprint -- creates blueprint code for the specified field.
