info("errorparameter")
The info(“errorparameter”) function returns the parameter that caused a runtime error.
This function is designed to be used in Error Handling code. If an error occurs in a parameter, this function will tell you which parameter it was. (Use the info(“errorstatement”) to find out what statement the parameter belongs to.)
- catcherror( -- evaluates an expression, but suppresses any error generated by that expression.
- error( -- returns an error with the specified message.
- errortext( -- evaluates an expression, but returns only the error message generated (if any).
