info("windowtype")
The info(“windowtype”) function returns a numeric value based on what type of view the current window contains.
This function returns a numeric value based on what type of view the current window contains. The possible views are:
Data Sheet ☞ 2
Form ☞ 5
Draw ☞ 6
Procedure ☞ 8
View As List Form ☞ 14
