info("fields")
The info(“fields”) function returns a carriage return delimited list of fields in the current database.
This function returns a carriage return delimited list of fields in the current database. If you want to get a list of fields in another open database, use the dbinfo( function.
- field -- tells Panorama to move to the specified field for the current record.
- fieldblueprint -- creates blueprint code for the specified field.
