info("modaldialogopen")
The info(“modaldialogopen”) function returns true if a modal dialog window is currently open.
This function returns true if a modal dialog window is currently open.
- activegrid -- manages the operation of a grid that controls a series of options.
- analyzedialog -- opens the standard Analyze dialog.
- closeallasyncprogresswindows -- closes any asynchronous progress windows.
- columnstatsdialog -- opens the standard Column Stats dialog.
- customdialog -- customizes the appearance of the gettext and getscrap dialogs.
- editfavoritesdialog -- handles the Favorites button in a dialog.
- favoritedatabasedialog -- opens the standard Favorite Databases dialog.
- favoritesbutton -- handles the *Favorites* button in a dialog.
- getscrap -- will display a dialog with a text entry area. The entered text is placed in the clipboard.
- getscrapok -- will display a dialog with a text entry area. The entered text is placed in the clipboard.
- gettextdialog -- displays a configurable modal dialog that asks the user to enter an item of text.
- importdatabasedialog -- opens the standard Import Database dialog.
- joindialog -- opens the standard Join Database dialog.
- morphalldialog -- opens the standard MorphAll dialog.
- morphdialog -- opens the standard Morph dialog.
- popupsharingmenu -- pops up a menu for the toolbar sharing icon.
- rundialog -- uses a form as a template to display a modal dialog window. The statement supervises the operation of the dialog until it is closed.
- rundialogmenus -- enables custom menus in a modal dialog.
- selectduplicatesdialog -- opens the standard Select Duplicates dialog.
- sortdialog -- opens the standard *Sort* dialog.
- supergetpassword -- will display a dialog with a text entry area for a password.
- supergettext -- will display a dialog with a text entry area.
