info("searchformula")
The info(“searchformula”) function returns the most recent search formula used in a find statement, if any.
This function returns the most recent search formula used in a find statement, if any. This is the formula that will be used by the nextmatch and previousmatch statements.
If there hasn’t been a search, this function will return an empty string (""
). Panorama uses this to disable the Find Next/Find Previous commands in menus.
