This page describes how to program a Text Display Object, including how to scroll, how to access and change the current selection, and how to access the text being displayed.
Most of the features described below are accessed by using the objectaction statement. This statement performs actions on a specified object. Usually the object is specified by it’s name, which means that the object must have a name. To learn how to assign a name to an object, see Object Names.
For example, suppose the current form has a Text Display object that you’ve given the name Notes Display. You could cause this object to scroll to the bottom with this code:
objectaction "Notes Display","scroll",-1
But remember, this will only work if you’ve set the object name to Notes Display.
The objectaction statement also allows the object to be specified by it’s ID value. You can use the objectinfoarray( function to find out the ID you need based on particular criteria, for example the field name. Suppose you want to start editing the field Body, but you’re not sure what the object name of the Text Editor object is, or if it even has a name. You can still find out what the object ID number is and open the Text Editor object with code like this:
let targetField = "Notes"
let targetObjects = objectinfoarray(
{str(objectinfo("id"))},
{objectinfo("Formula")=targetField and objectinfo("class")="TextDisplayObject"})
if linecount(targetObjects)=1
let targetObjectID = val(targetObjects)
objectaction targetObjectID,"scroll",-1
else
beep
In this example, the objectinfoarray( function scans all of the objects in the current form.
{objectinfo("formula")=targetField and objectinfo("class")="TextDisplayObject"})
If it finds a Text Display object that is associated with the Notes field, the ID of that object is placed into the targetObjects array. (This formula checks to make sure that the object is a TextDisplayObject because we want to skip over other types of objects that could be associated with the Notes field, like text editors, data buttons, popup menus, or text lists.)
The if statment checks to make sure that we found one, and only one object.
If we did find one object, we need to convert the ID value from text into a number.
With this ID number we can now perform actions on this object.
If the form doesn’t contain an text display object for Notes, or if contains two or more such objects, this code will beep.
Now that we know how to identify the Text Editor object that is the intended target of an action, the rest of this page will discuss the various actions that be peformed.
If the vertical scroll bar is enabled, the text in the Text Display object can be scrolled up and down. Usually this is done manually by clicking and dragging on the scroll bar, but this can be automated. For example, this code will scroll the Notes text display object to the top.
objectaction "Notes","scroll",0
The 0 in this case tells the Panorama what character to scroll to, in this case 0 is the very first character being displayed (the top). You can also specify the position as a negative number, which indicates the position from the end of the text instead of from the beginning. So this code will scroll the Notes to the bottom.
objectaction "Notes","scroll",-1
You can also scroll to any position in between.
Note: If the Auto Scroll to Bottom option is enabled, the text will automatically scroll to the bottom whenever the text is modified. Suppose your Notes object is linked to a variable named myNotes. You could add a new line to the notes with today’s date like this:
let myNotes = sandwich("",myNotes,cr())+datepattern(today(),"Month ddnth:")
showvariables myNotes
If you wanted the text display object to show this new line, you could modify this code like this:
However, if the Auto Scroll to Bottom option is enabled, this extra line is not necessary. Simply using showvariables will cause the text to scroll.
Note: If the Text Display object allows text to be selected, scrolling the text via code will cancel any text selection. If necessary, you could save the selection, scroll, then re-set the selection (using the techniques described in the next section).
If the Allow Text Selection option is enabled, the user can click on, select, and copy the select text that is being displayed. You can also manipulate the selection with code.
To find out what the current selection range is, use the "getselection"
action. This must be followed by two variables that will receive the start and end points of the selection. This code will display the number of characters currently selected.
local start,end
objectaction "Notes","getselection",start,end
if start=end
message "Insertion point"
else
message pattern(end-start,"# character~")+" selected"
Note: The selection range values start at zero, not one. So if the first five characters are selelected, the start of the selection will be 0 and the end of the selection will be 4.
To change the current selection range, use the "setselection"
action. This must be followed by two values for the start and end positions of the range. This code selects the first character of the text.
objectaction "Notes","setselection",0,1
If you specify negative values, they will be counted from the end of the text. This code will select the last character of the text.
objectaction "Notes","setselection",-2,-1
To select all of the text, use:
objectaction "Notes","setselection",0,-1
It’s ok to specify a number past the end of the text. This code will probably select all of the text, even if there are only ten characters. (But to make sure, it’s better to use -1, which will work even if there are a million characters.)
objectaction "Notes","setselection",0,9999
Since the text being displayed is generated by a formula, you can usually simply use the same formula in your code to find out what the text is. But sometimes that’s inconvenient. To find out the what the text is currently is right this moment, use the "gettext"
action.
local dtext
objectaction "Notes","gettext",dtext
To find out what the currently selected text is, use the "getselectedtext"
action.
local dtext
objectaction "Notes","getselectedtext", dtext
To copy the currently selected text into the clipboard, you could do this:
local dtext
clipboard = dtext
Of course the user could also simply press Command-C for the same effect!
