info("accessorypanelwidth")
The info(“accessorypanelwidth”) function returns the current width of the current window’s accessory panel, if any.
This function returns the current width of the current window’s accessory panel, if any. The width is returned in points. If the width is zero, the accessory panel is not visible.
